rest 1994 q45 ecu
cjnicks
Car: 1994 infiniti q45
whats up everyone. i have a 94 q45. My problem is that it will not......pick up rpm; like it dosent go over 20000 rpm. it will just sputter. i have already changed a fuel pump and fuel filter and there is no difference. Now i am looking at the ecu. Does anyone know how to reset an ecu? Or does anyone have any other suggestions. PLEASE HELP!!!
PapaSmurf2k3
Site Admin
Moved.
If your Q is anything like other Nissans, it sounds like maybe your Mass Airflow Sensor is bad.
cjnicks
Do you know how much that would cost?
Q45tech
Pre OBD2 [1996] ecu don't have much of a memory other than for codes and a fine tuning at cruise which goes away when the battery voltage is removed for a few hours.
The same keep alive circuits for clock, radio, seat position supplies the voltage.
ECU memory doesn't have anything to do with failure to start or limits of 2,000 or 3,000 rpm which are fail safe limits caused by a loss of CRITICAL signals from sensors like CAS, MAF, TPS.
cjnicks
ok thanks. but how do i check to see which one is the one that has gone bad?
PapaSmurf2k3
Site Admin
Q45tech wrote:like CAS, MAF, TPS.
TPS is considered critical? I've disconnected mine on my 240 many times, with minimal effects.
cjnicks
ok thanks guys for the help. I will have a pic of my q45 for everyone to see soon.
cjnicks
i just talk to my father and he said that he already changed the tps sensor. Soooo, that leaves us to check the maf senor and the cas. by the way what does cas stand for?
PapaSmurf2k3
Site Admin
crank angle sensor.
IIRC, you should be able to hook up a multi-meter to the MAF and make sure it is within spec. I recommend you download a factory service manual.
cjnicks
i will. i just got back in the house from looking at the car; looking for the maf sensor we could not find it. n i dont know what it looks like. i am such an amateur at this. do u know where it is located on the engine?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Right after the air filter.
Got FSM?
http://www.nicoclub.com/FSM/Q45/
Q45tech
Crank Angle Sensors [CAS] rarely fail but the connector and harness connections do get corroded and intermitent.
The CAS send out 360 INDIVIDUAL pulse per rpm signal [with one triple wide pulse where 0 degrees is located] and a seperate every 90 degree pulse used for cranking and emergency use [fail safe].
This is the Master Clock which tells ecu where #1 cylinder is timewise and each subsequent cylinder occurs 90 degrees later [on a V8].
Important to mentally and physically view all the pulses from CAS and understand their relationship timewise.
