Both are a lot of work no matter how U look at it. I have pulled engine and trans threw the top. Engine alone threw the top. Dropped engine and trans. both threw the bottom and it all depends on where and what and who U are working with. If U pull engine threw the top by itself U will catch hell if U are a beginner. I drain the antifreeze and oil and power steering/trans fluid and releave fuel pressure. Main Engine harness has to be disconnected and I remove radiator and hoses and trans lines and starter wires. Also take 6=14mm nuts off of exhaust manifold flanges and the two trans to engine braces that have 4=17mm bolts 8 total that attach to the engine block and trans have to be removed to access the converter bolts. Battery disconnected and I also remove the EGR Tube from the EGR Valve and the exhaust header to prevent damaging which is 24mm. trans dip stick is removed and trans cross-mount and exhaust hanger along with 4=14mm drive-shaft center carrier bolts to allows for additional clearance. I use the engine hoist/cherry picker to support the engine when I start removing the main bell-housing bolts. This prevents the bolts from binding when the Eng. and Trans. start to part. The top 4 are 19mm and I found it is best to use a 19mm stubby boxed end wrench that I attach a long wrench to so I can break the bolt loose. There after I can get my racheting wrench on to speed up the process and the bottom bolts are 17mm that attaches to the braces which at this point should already be removed! I have just told U the majority of the things not all like(removing accel. cable and MAF TUBING) ETC. and this was not in the order that U can do this. U can drop the motor and trans as a unit faster from the bottom but, U need the right Equipment and tools to do this. The VH45DE is one of the most MASSIVE ENGINE and Trans combos that I have ever seen in a car or truck.goingbroke wrote:Thankyou for solving my delema whether to pull the engine out the top. It will come out the bottom now that I have information confirming it is near impossible to pull it out the top.
thankyou
Dean
First off why are U removing the engine? Just make sure that U do all that U can to the engine while it's out. Check for any damaged or leaking parts. Alot of times VH45DE'S have leaking rear cam seals at the back of the valve covers. Valve covers leak on these also and some even have exhaust manifold leaks. I remove the 02 Sensors and check to see how they are performing. Some gut the pre-cats and some don't. Check your oil pan and crank and rear seals for leaks also! Position the engine on a slight angle instead of level to help with clearance during install. Remove your converter and empty and refill with fresh fluid or even better install a new converter or have yours rebuilt. Clutches normally will wear and cause excess slippage.goingbroke wrote:Thanks for the information PopPop Today I started tearing into project. I've tackled some tough projects before but this engine change is hands down a doosy now matter how a person goes about it. Tomorrow I will have the accessories pulled off and do more analyzing at the complexities of pulling motor out the top with or without the transmission. Any advice on reinstalling engine to transmission after pulling engine out the top? Hey thanks for the info sure appreciate it
ThankyouDean
