Resonator Box Removal???
nysc
What is Resonator Box?Is it necessary for performance??Does it help RPM response when I remove it?Thanks...
specialkonrd
use the search featureits the big red button at the top
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
The resonator box is part of the air intake. It basically acts like a muffler for the intake. Removing it might help a little. It really doesn't restrict airflow, but it does increase the air mass within the intake which MIGHT reduce the ability of the intake to pull efficiently. It is not necessary. If you have an s14 it is located infront of the front, driver's side wheel well. It is easy to remove.
SilviaLuvr
Car: shopping for parts going to school to become a massage therapist
Not really...removing the airbox will f^ck up your O2 senors TRUST me i know THAT IS unless your putting in an cai that will bypass that problem
zachosz
Car: NONE!!!
Where did you get that from? What's the O2 sensor have to do with it???
specialkonrd
i know? what's that got to do with it?
only thing u might **** is the EGR since that has a hose that connects to the air box
S14Zilvia
Car: '90 300ZXTT, '92 S13 coupe, '06 Ram 3500 Mega, '93 del Sol Si
SilviaLuvr wrote:Not really...removing the airbox will f^ck up your O2 senors TRUST me i know THAT IS unless your putting in an cai that will bypass that problem
In a word, No.
red240ne
Car: mmm...donuts
specialkonrd wrote:i know? what's that got to do with it?
actually it's AIV. sorry, not trying to be a smartass:)
specialkonrd
erryeah tahts wut i meanthehe
