Resonating body, CV or Bearing?
TheBiffCunningham
Car: 2011 Nissan Rogue SL AWD - 79,000
1992 Volvo 240 DL - 189,000
2011 Rogue SL, resonating at high speeds ~40+
Sounds like.. "wwwumpp.......wwwumpp.......wwwumpp"; a low pitched hum.
Frequency increases when veering left and decreases to a steady resonance when veering right.
Suspect Front-Passenger CV or Bearing issue. Not related to acceleration or braking. Tires are balanced and were rotated without effecting the symptoms.
Any experience w/ these specific symptoms, and opinions on source?
Rogue One
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
A humm that changes in intensity when turning left or right is most often a wheel bearing. Usually the opposite side from the most noise. In other words if I'm reading your post correctly, the noise increases when turning left, in which case it is a right wheel bearing that would be bad.
Return to “Rogue Forum”
