if i got the de-icer stuff will i have to spray it into the door lock every time it gets frozen, or does it last a while and prevent it from freezing in the first place?1SickSilvia wrote:most car part stores carry a product called " lock de-icer" eighter in a spray or a tube, if you can t find it let me know, and I could get some for ya, here in Canada its a standard winter item ,
Yes you would have to spray it each time, when its frozen but if you used this stuff on it before, it dosent really freeze up after.DropTop240 wrote:
This will work, too. I would do the WD-40 now, and carry a lighter with me just in case.240DrpTop wrote:I would spray them with WD-40. Insert the small red tube into the lock and give one spray. Good Luck!
