resistors
hinds90
Car: 89 240 sx
Just want to know if I can use 100 ohm 1/4 watt resistor or do I have to use a 100k ohm 1/4 watt resistor . Went to radio shack and they didn't have 100k.
Import_Ant
Why are you crossposting this? your question doesnt even contain enough info to be answered...
S13FX
Car: '69 l20b Dimeski :)
Yah what resistor are you talking about? You made the same post in the other KA forum too.
Please elaborate.
hinds90
Car: 89 240 sx
Sorry about the double post it was a mistake. I have a 95 s14 and I think this motor may be from a 97-98. I have 2 egr related codes
p1401 EGR temp sensor p1400 EGRC solenoid
I know sooner or later I will be turbo charging the car so I just wanted to go ahead and take off all of the egr related stuff. I went to radio shack to get a 100k ohm 1/4 watt resistor that you use to put into the female connector for the egr temp sensor to fool the ecu into thinking the sensor was getting correct temp.
Well they didn't have the 100k ohm 1/4 watt resistor but they did have 100 ohm 1/4 watt resistors so I was wondering could I use those instead.
hinds90
Car: 89 240 sx
Are there any other places I can get resistors from.
