coolhand »
https://forums.nicoclub.com/coolhand-u34947.html
Mon Dec 05, 2005 2:22 pm
I have a 95 Max and I replaced the knock sensor in less than 20 mins (time may vary due to mechanical experience). Tools needed:
1. 12mm universal socket (not a regular socket and universal adapter)
2. ratchet extension that are 1 and a half feet long more or less.
(you may have to move a vacuum control solenoid to gain hand access)
Use this setup to loosen the bolt and you MUST USE THE KNOCK SENSOR TO CARRY THE BOLT OUT!!! To install:
PLUG THE WIRE HARNESS TO THE NEW KNOCK SENSOR FIRST!!!!
1. (Depending on the size of you hand) put the bolt in the new knock sensor and use you hand to guide the setup in the hole(scaring on hand may occur)
2. use the tool setup to torque the bolt.
NOTE:
If the bolt does not move, DO NOT FORCE IT!!!
Make sure the bolt started in the hole correctly, DO NOT FORCE IT!!!
I have been a mechanic on and off for 20 years and I did the knock sensor myself hope this helps.
Coolhand
1995 Maxima SE 5spd
