resistor for EGR codes ????
mikesloud
Car: turbos and SPL world champ
I have heard you cAN get a resistor 100k ohm put on egr temp sensor wire ,and it will stop egr code? 95kado you put in line with it ? or cut sensor wire off and put resistor in and ground one side?do you add
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
mikesloud wrote:I have heard you cAN get a resistor 100k ohm put on egr temp sensor wire ,and it will stop egr code? 95kado you put in line with it ? or cut sensor wire off and put resistor in and ground one side?do you add
zerothread?id=94395
Modified by rn240sx at 11:26 AM 6/10/2006
