SPE777 »
https://forums.nicoclub.com/spe777-u16450.html
Mon May 02, 2005 12:21 pm
Hi guys,
My car is throwing a code for the MAFS and Map/Baro switch on my '97 240, and before I replace both, I'd like to check the voltage on both to find out where the short is. Does anyone know what the resistance levels are for either component?
Also, is there anything else intake related I should look at? I've gone over all the vacuum lines, even with carb cleaner, and had no success!
Thanks!
PS- I've found nothing thru the search function.
