Resetting the Tire Pressure Monitor
The_Scooch
Car: 2006 Infinity G35 6MT Coupe
I did a search on this and came up with something about a car wash screwing up a guys tire valve...
Is there an easy way to reset the TPM myself? It seems the slightest change in pressure activates mine and when I add air, the light stays on anyway. Ive been to the dealer 3 times for this and each time they make me wait about 30 minutes before they reset it. Nothing is ever wrong according to them.
Thanks.
C-Kwik
I'm not aware of a way to reset this yourself. You shouldn't need to. Whenever I had a tire with low pressure, I simply put more air in and it was fine. Perhaps one of the sensors is intermittently malfunctioning?
infinititech1
the are supposed to be 35psi cold... set them to that...and drive at a speed over 20 mph for a few mintues and light should go off
The_Scooch
Well as it turns out, they were all off by 5 psi. That's pretty accurate pressure monitoring. I had them set at 35psi but over time they all went down the exact same amount. Amazing.
Others seem to have many complaints about their G, I have been nothing but satisfied.
The_Scooch
I had them set at 35 but "surprise" they all went down to 30 over a 2 week period. It could be that the weather here has cooled down rather quickly. I am amazed at how accurately the sensor caught the change.
Thanks for the info.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Weather plays a tremendous effect on tire pressure.
Q45tech
Just like engine power a 11F change results in a 1PSI [or 1% engine change]..............plus of course the natural 1 PSI per month of leakage.
The_Scooch
For those people obsessed with performance mods to extract 3 additional HP, they should move to cold climate as a considered mod. Imagine, you could dump the intercooler just by moving to Canada! LOL!
szh
Car: 2018 Tesla Model 3.
The_Scooch wrote:I had them set at 35 but "surprise" they all went down to 30 over a 2 week period. It could be that the weather here has cooled down rather quickly.
Not surprising! For this good reason, I check my tire pressures with a good gauge every other weekend or so and they all consistently, and typically, drop about 1 to 2 psi during that time (measured inside my garage in the morning, i.e., cold tire reading). That is normal "leakage".
If the weather changes unexpectedly, I check more often ... but that is not really likely in the San Jose area!
Z
