I have a strong feeling that my timing is the cause of my bogging/hesitation issue. I have pretty much tried EVERY THING that I could.
I have tried looking for vacuum leaks (found one...fixed it, still have the bogging issue), changed spark plugs, wires, dist. cap, rotor, O2 sensor, oil, EGR valve, BPT valve, AIC (the part that connects to the air intake box), new gas, air intake cleaner, MAF connections, etc
I took the valve cover off today and noticed that the timing chain guide is completely gone. I have a feeling it broke off. I wonder if this caused my timing belt to jump a tooth or two. Anyway, how hard of a process would it be to get my timing (if it is off) back to where it should be without messing with the timing belt, it is possible at all.
Any help is greatly appreciated.
Is it the way described in this link under the, "Timing Change" link?? http://www.240sx.org/faq/index.html
I just want to get my 89 240SX running.
Thanks
Andy
EDIT: I meant to say timing chain. I am just used to saying timing belt.
