hmm i already try your "correct way" but cannot work, any advise?EZcheese15 wrote:Here's the correct way to do it (article says Maxima, but it's the same on all throttle-by-wire Nissans):
http://www.nicoclub.com/articles.php?id=158458
But changing the exhaust should not affect the ECU unless you removed a cat. And even then, that would only be a temporary fix to clear the check engine light.
On a low HP 4 cylinder car such as the Versa, an exhaust is going to add very little HP. You're probably looking at the 3-4 HP range with a good exhaust. As a general rule of thumb, it takes approximately 10 HP to register on your butt dyno. You're only going to see 10+ HP differences with exhaust on larger engine cars, like V-8's. Not only do 4 cylinders have very little to gain with exhaust, but newer cars have even less. Factory exhausts these days are pretty free-flowing already.
Use a stopwatch. The times in the procedure above are very exact and if you are a second off on any of the steps, it won't work. It might take a few times to get it right the very first time you do it.t19uz wrote:
WOWHOHO i've made it!!! yess using the STOPWATCH!!! thx a million bro........ it feels like ... finding a secret in a video game hahahaha....EZcheese15 wrote:
His location says Jakarta. I'm sure they don't use the same R+M/2 octane calculation the states use. They probably use just the RON, which is roughly equal to 91 R+M/2 octane.biggie wrote:ECU cannot learn about wheels/tires. Your speed sensor cannot adapt to different sizes.
It may help in Octane (but seems like you are way too high on Octane, depending on that engine), but if it changes anything it will not be enough for you to notice.
Check the owners manual, and also check the fuel station to see which octane formula they use. It differs in each country how it is calculated.t19uz wrote:oww so u mean that 95 is wasting money? so what is the proper octane for the MRDE18?
Thx in advanced.
