vpnavy »
https://forums.nicoclub.com/vpnavy-u61300.html
Sun Nov 04, 2007 1:26 am
Well, it is time to set back our clocks. Have any of you tried that in your V's?
I am totally shocked at how fouled up it is in the Versa. I can only do it on the hour! I just can't believe this! Right now it is showing 7:02 and it is actually 6:02 - So I guess I keep reseting it (don't go beyond :29 back to 7:00) Then, at exactly 7:00 (but before :29) I reset it. I just can't believe this!
Resetting the time
Hold the MENU button down and then press the TUNE/SEEK button, the time will reset as follows:
o If the displayed minutes before the reset are in the range of :00 - :29, the hour displayed before the reset will stay the same and the minutes will be reset to :00.
o If the displayed minutes before the reset are in the range of :30 - :59, the hour displayed before the reset will advance by one hour and the minutes will be reset to :00.
For example, if the MENU button and the TUNE/SEEK button are pressed while the time displayed is between 8:00 and 8:29, the display will be reset to 8:00. If the buttons were pressed while the time was between 8:30 and :59, the display will be reset to 9:00. At the same time the display will return to the audio.
Well, time got away from me and I missed it by two minutes! Not it is 7:03 and my Versa says 7:00! Guess I will have to play with it twice (over the next hour) to get it right.
Modified by vpnavy at 7:14 AM 11/4/2007
