SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sun Mar 29, 2009 3:12 am
Here is a step by step break down of the relearn procedures that can easily be reset if the battery is drained or disconnected. This is much easier than trying to reset a CEL or idle volume learn using key cycles and gas pedal activation.
INITIALIZATION PROCEDURE
If the battery is disconnected, the sunroof motor connector is disconnected sunroof does not close or openautomatically, use the following procedure to return sunroof operation to normal.1. Close the sunroof if it is not in the closed position. It may be necessary to repeatedly push the switch to close the sunroof.
2. Press the SLIDE OPEN/TILT DOWN switch for approximately 1 second or more.
3. Initialization procedure is completed. Confirm proper operation of the sunroof (slide open, slide close, tilt up, tilt down.)
As a Quick add-on here is the reset procedure for the Auto window functions.
SYSTEM INITIALIZATION
If any of the following work has been done, initialize the system.- Electric power supply to power window switch or motor is interrupted by blown fuse or disconnecting batterycable, etc.- Removal and installation of the regulator assembly.- Removal and installation of the motor from the regulator assembly.- Removal and installation of the harness connector of the power window switch.- Operate the regulator assembly as a unit.- Removal and installation of the door glass.- Removal and installation of the door glass run.
Initialization
After installing each component to the vehicle, follow the steps below.1. Disconnect the minus terminal of battery or disconnect power window switch's harness connector temporarily, then reconnect after at least 1 minute.
2. Turn ignition switch ON.
3. Open the window to its full width by operating the power window switch. (Exclude this procedure if the window is already fully opened)
4. Fully draw the power window switch in up direction (auto close position) and hold, keep holding the switch even when window is completely closed and then release after 3 second has passed.
5. Inspection of the anti-pinch system function.
NOTE: Initialization may be canceled with continuous opening and closing operation.In this case, initialize the system.
