Reset ECU
juiceman
Is there a way to reset the ecu without consult?
I am getting the new MAF and spark plug tomorrow and the tech told me to reset ECU after installing so the ECU will learn from the new MAF
Any suggestions?
Q45tech
The short term/long term block learn trims readjust pretty fast when driving. I noticed that it takes around 5-10 minutes at 60 mph.The ecu learning must self adjust fast for driving down a mountain when things [air density] change 3-4% in 1,000 feet.
The ecu capacitors will discharge if you take the + battery terminal off for 30-60 minutes or so....but you have to reset the radio, clock, etc.
juiceman
Thanks,
I will remove the battery cables
I am not worried about the radio because it hs the Bose problems and need to be service anyway
thanks, this car is so different from any car I previously owned I just wanted to make sure that would work
DAEDALUS
Car: 1990 Infiniti Q45
I'm not certain, but I thought the manual said that the airbag sensors aren't safe to work around until 24 hours after battery disconnect.
