Reset codes T32 xtrail/rogue hybrid 2018 tail gate
mahabirandrew1
Car: T32 Nissan x trail/ Rogue hybrid 2018
How can i reset the factory memory for the tailgate of my T32 xtrail, the code B2409 half latch switch memory has been removed and this error came up and the trunk/tailgate won't open either with the cabin switch, tailgate manual switch nor the key fob.
How do i reset to the factory memory default settings for this operation.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Topic moved to correct forum.
Did you try pulling the fuse?
mahabirandrew1
Yes, still not reset
Thanks
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Since there does not seem to be any 2018 shop manual available try the 2016 that is available. There should be a reset procedure outlined in the DLK (doorlock) section. It’s a pdf that is 403 or so pages, check the first page index but the locking system is discussed starting at around page 20.
https://nicoclub.com/FSM/Rogue/2016%20Rogue/DLK.pdf
Return to “Rogue Forum”
