reset 2007 nissan quest instrument panel
A forum for the Nissan Quest... minivan lovers unite!
merrittr
Car: 2007 Nissan Quest
what is the process to reset gauages in a 2007 nissan quest?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The only reset is for the trip odos and trip computer, you do that by holding in the button underneath the speedo. There's a diagnostic function for the cluster, see DI-14 here, but if one of the gauges is misreading when you run the diag, the cluster is bad. If it reads correctly in diag but not in actual operation, you probably have a sensor or wiring issue.
https://www.nicoclub.com/service-manual ... 7%2Fdi.pdf
Return to “Quest Forum”
