let me know how you like your 270s after you lay into her a few good times i really want to rev about 8500 and 270s should look nice with those rpms also help that tq curveDrifterProdigy85 wrote:Stay 264 if your keeping the rev limiter at 7500rpm. Go 272 if your gonna rev over 8000rpm. I had BC 264 cams, honestly i like my HKS 264 cams better. I now have Tomei 270 cams. They can idle rough from time to time. My motor is still new so i havnt driven it into the powerband yet to feel it. I dont expect power to hit hard till 5krpm though.
yeah you can see my modsin my signal below.ems microtech LT-8GT2871R turbo w/ .86 arstock internalsexternal wastegate 38mmhybrd intercooler 24x12x3 core 720cc injectorsFPRand slicksabout 16 psiR-Yahne_240 wrote:Dugi would you mind hittin me up with a list of engine mods that you have running 11s not bad how much boost on you gt2871r????
ha ha ha ha i feel you man well its junkyard part and im gonna slip my boy 50 buck to pull all the stuff for me thats all its gonna cost metenkawa_akito wrote:This is my personal opinion. If you want to drag, don't use a viscous diff. The viscous fluid will heat up and deteriorate quickly, and then you just have an expensive open diff. For drag, I'd suggest a clutch type, or if you're super poor, a welded diff (I can't believe I just suggested that)
Its not my daily driver but is daily drivable. My rev limiter right now is 8500rpm which is just limited by the BC Valve Springs not having enough seat pressure to rev higher safely with the Tomei Solid cams. I run Tomei Solid Lifters too. Wouldnt try to rev over 8krpm without solid lifters.R-Yahne_240 wrote:
is that your street car??? and whats your limiter
Drove my SR today for a short time. Layed into it a couple times to see how it spools and when power really comes in. WOT throttle from 3500-5500rpm. Was hitting 14psi in the low 4000rpm area which is normal and could feel the power come on most around 5k-5200rpm. Below that it felt kinda like a teaser. Turbo was spooled but didnt have that kick yet. Only have about 10 miles on the motor so im not about to redline it yet. Also the solid lifters are alot more noticable than stock. Has a fient tap to em which is to be expected. Personally, if your looking for a car to have good response and power, get the largest set of 264 cams you can find. Ive always like HKS and Tomei. Might even want to check out JUN.R-Yahne_240 wrote:
