andbeyond »
https://forums.nicoclub.com/andbeyond-u35667.html
Sat Nov 25, 2006 9:45 am
got both the valve covers off, bent the EGR pipes just enought to clear the cover.
You do not have to disconnect the fuel lines on the passenger side, mine is a 93 Q45. I removed the top radiator hose (at the engine, not the radiator) and pulled the cover away from the engine and slid it foward, and out.
Most have said the passenger side is the easiest to remove , I would take the drivers side over the passengers side anyday, much easier, no ABS pump and AC lines to deal with.
now to clean, apply sealant and reinstall.
