Resealing differential cover on 91 Q45???
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
Would using copper RTV be okay, instead of using the OEM paper gasket when resealing the case to my differential???
Q451990
I'm not sure if there are many members here who have actually done this - but my first instinct would be to go with the OEM gasket. From looking at the service manual, it looks like there are some moving parts pretty close to the edge of the differential case, so RTV "squeeze out" would be a concern too.
Heath
qship96
Car: 1996 Infiniti Q45
Why risk it when the oem gasket is proven to last almost forever? Mine has no leaks at 282K
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Obvious question. After all, this isn't an Audi!
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Does anyone know the part number to the OEM gasket? Can I find it in the FSM?
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
I ended up using the Permatex Gear oil RTV, it's suppose to be resistant toward synthetic gear oils, I ended up torquing the cover to about 15 foot pounds after filling it with Royal Purple, I just wasn't trying to visit the Infiniti dealer, its been okay, I was also skeptical using RTV that was not specifically made for this, like the copper RTV, however the gear oil RTV reminds me of that Ultra Grey stuff, could be the same thing just marketed differently???
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
You saved $18.19 less the cost of the RTV. My point is I used RTV on my transmission pan for one day and it was leaking fluid all over. I replaced the RTV ASAP but Dexron 3 ATF and differential oil are a little differnt.
