nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Fri Oct 02, 2015 7:17 pm
Remember we also talked about a reputable nissan(Z) shop. Just having anyone work on these cars could very well be detrimental. All OEM stuff
Properly re-building the Z, lets take your 80/hr in consideration
Min 15 hours to pull, take apart for timing, heads, crank, block, etc $1200
120K timing $490
Engine Hone deep clean $300
Heads only resurfaced $150
Reseal kit $250
Rings, bearings, etc $120
Fluids $100
Shop fees $50
Taxes (being generous because states diff) $60
Spark plugs $50 ish
This alone is $2770, this doesnt include if they charge extra to install timing belt, time the car, anything with the clutch, if the mounts are shot, hoses went bad(bypass hoses), under plenum hoses, if valves are bad, guides are bad, cranks haft needs grinded, head bolts, etc.
Personally 15 hours, that is not enough time to rebuild an engine with taking it out and reinstall, I think it should be closer to 20-25. So 3k is very conservative number, some can get it done cheaper some will be more expensive. I think if you went to Pitstop in phx, which specializes in Z's, they quote a rebuild close to 5k with install. I talked to them a lot, they charge I think 120/hr.
You can go cheaper on parts, but don't. They don't last as long, cause issues, and sometimes do not fit. Timing stuff is the worst to go cheap on, that s the heart of the car, that is what keeps it going.
