requirements to prep a used 50k miles redtop?!
scottyvEE3
Car: 96 Maroon 240sx , B&N short shifter, Apexi exhaust, walboro 255 fuel pump
i should be getting a sr20det redtop, by tomorrow from JAPAN STAR MOTOR in ALBANY NY. and want to know what i should do first before i actually install the engine into my car. im not sure if theres a thread or sticky on this topic. havent really had time to do alot of researching so just decided to post a thread, if anyone could actually inform me and help me.
mRodiek
Car: Stock Hatch
if you wanna go hardcore...all gaskets/seals, new pulleys/belts, plugs/wires, hoses, clutch/flywheel...that should keep ya busy for a while lol
nzmoman
Car: 240sx 2 of em' and always lookin for more
look at one of the swap threads...
everything you will need to do and everything that you may want to do are listed in install threads
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
If you are going to use the stock intercooler, take it to a radiator shop and have them pressure test it.
Emperor_Tha
I would replace headgasket, brand new oem or even go metal headgasket and brand new timing chain
scottyvEE3
well local shop said they be doing like the basic car tune up to the engine. and as far as the stock intercooler, thats something ill keep in mind
imSUPERjon
Car: 91 240SX S13
i took all the accessories off the block, bought an oem gasket set from ebay (it has all of them) took the block assembly to a machine shop and said break it down, change gaskets, inform me if anything is wrong and we'll go from there. i'm happy because my crankshaft was all jacked up (i looked at it too cuz they were cool with that...i hope). they said it was about to throw rods 2 and 3 because there was too much play. the walls around the journals were ground down a lot.
really i did all that for peace of mind, i'm really glad i did it. set me back the amount of another sr though so yeah, if that's not in the budget, go to church, pray, then just replace all your gaskets, probably the clutch assembly, and maybe some hoses. use that bronze or copper spray stuff on your gaskets, makes em sticky. and water pump, mine was crappy. you'll probably have to remove the studs from the old one (i just did that). and thermostat. and if you're hardcore, oil pump. mostly maintenance stuff.
ebay high cap. oil pan! (the bonus is the engine sits upright on its own now (a little tilted) cuz the oil pan is wider!
then injectors, spark plugs, oil filter, fuel filter, etc blah blah blah....
and don't worry about the timing chain, cuz if that really is f-ed up, you've probably got other problems. those things last forever though. really. nissan says so!
hope i helped
Modified by imSUPERjon at 5:31 PM 10/17/2008
Narciso
Car: 180SX
Hoses definitely. You should check the head also. Make sure your lifters don't have any air in it. Check the rockers too. Make sure they are smooth and mirror like. Since the engine will be out of the car, you should up grade the head gasket/head studs. Also if you decide to upgrade the head gasket, you should change out the intake manifold gaskets. I would have someone weld the the nut on the far left and right of the intake manifold (where the top meets the bottom) so that it is easy to take on/off. That thing some what of a pain.
Fuel filter, change to steel braided hoses for the water/oil lines on the turbo or change to new stock ones, make sure the oil return line on the turbo is good, and what DriftBoy07 said. I know it may suck and hurt your pocket a little but do it right the first time. Buying an SR20DET is an investment. Take care of it and spend money now to avoid spending a lot more later.
jdmshiz
DriftBoy07 wrote:if you wanna go hardcore...all gaskets/seals, new pulleys/belts, plugs/wires, hoses, clutch/flywheel...that should keep ya busy for a while lol
how much would it cost to do all that except the clutch and flywheel??
exhsturbine
Car: 1997 240
zer...age=1
positron's been making this amazing write up. i suggest reading and subscribing.
