requirements for an sr20 swap into s13?
vossman21
hi guys i was wondering if there are anythings that i would need to purchase seperately to complete my sr swap,example such as maybe a different radiator? I will be putting this in a 91 s13.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
1. a good motor2. fmic3. fuel pump4. gasket set5. a good motor6. lubricants7. cooling system, or (if your using a ka radiator you will need hoses)
Nacho_240
Car: 1991 240sx LE
and if you don't want any problems you better add on these to your list:
Bigger fuel filterbypass valveoil coolernew motor mountswater pump oil pump
OP, you're best off searching because I doubt anyone here is going to help you out more on a topic that's been covered in great detail multiple times.
jr_ss
Car: 95' S14
And the search button...
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
What is ths bypass valve you speak of? BOV? No?
Nacho_240
Car: 1991 240sx LE
Yes, blow of valve. The term "bypass" is frequently used when the BOV is recirculated back into the intake.
