lmheim »
https://forums.nicoclub.com/lmheim-u232318.html
Sun Jun 29, 2014 9:41 am
This is pretty silly but I can't figure out what the FSM is showing. All I am trying to do is adjust my low beams on my 02. The FSM indicates there is an easily accessible - and readily visible - adjustment screw. I have looked several times with a flashlight and simply can't find anything. I did find some sort of what I think is an adjustment, but probably associated with the leveling system. It is a bolt with a white plastic "sleeve" or cover, which is located inside a black plastic cylinder that protrudes from the back of the headlamp assembly, next to the HID bulb socket. I messed with that for a while and there seemed to be no change in the beam adjustment.
I am so confused and my low beams are adjusted at such a low position that it is dangerous to drive at night. The top of the low beam pattern cuts off with a distinctive squared off shape at the top of the beam.
Thanks for any assistance.
