Reprogramming Key FOB 94Q
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
What's the way to reprogram a new key FOB (tried searching here first-didn't find it.
Thanks!
Peter
litlchi
The directions are at http://www.q45.org/remote.html but basically it's this: (copied from their website)
While sitting inside the vehicle:1. Open the trunk.2. Close and lock all doors.3. Insert and remove the key from the ignition six times within 10 seconds.4. Manually unlock and lock driver's door once to enable "setting" mode.5. Push lock button on the new remote controller once, just long enough to hear it beep, within 5 seconds of completing step 4.6. If additional remotes are needed (up to 3), repeat steps 4 and 5 for each additional remote immediately after programming the first remote. (Note: a total of four (4) remotes can be programmed to function on the same vehicle).
Peterofdevon
Thanks and the link ref'd me to the FSM section I could not find:EL-pg161
Peter
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It's in a TSB, both have been posted here many times.
