reprograming
crimsone96Q45
Car: 1996 Q45
is there anyway to reprogram the codes without having the car taken to a shop ? any advice would be appreciated
szh
Car: 2018 Tesla Model 3.
crimsone96Q45 wrote:is there anyway to reprogram the codes without having the car taken to a shop ? any advice would be appreciated
I assume that you have a 96 Q (from your username) and that you are trying to reset a code that caused the CEL to come on? It is not clear from your post what you mean.
If you are simply trying to find out what caused the light to come on, and then reset it, you can borrow an ODB-II reader from your local Autozone and do this.
If it is something else that you wanted, then a bit more elaboration is needed!
Z
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Indeed elaborate a little, we'll help out. WElcome to NICO!!
crimsone96Q45
Car: 1996 Q45
yes that is the problem. i read on a different post that the air flow meter can sometimes get out of whack and cause the cel to come on as well as the bucking and hesitating, so i thought that i could reprogram the codes to see if thats the problem before i go and buy a new air flow meter.
thanks,
