phmichel »
https://forums.nicoclub.com/phmichel-u237795.html
Sun Jul 06, 2014 4:15 pm
Greetings Everyone. I'm new here. Just go a 2013 Rogue S AWD and really like it, but I have a comment and a question.
Comment: The manual says that the little button on the side of the shifter turns O/D off, but it appears to me it just shifts down to low range. This feature and button is not designed well IMO, unless I'm not understanding the intended function. If this button is pressed at hwy speeds the engine will rev to 4k and higher. Me no like.
The Sport button makes much more sense, simply adjusting the shift points. I like this and use it when descending a hill at med or hwy speeds because it drops the CVT into a lower ratio, but not down into the low range.
Questions: Is is possible to reprogram the sport button to be actuated by the little button on the shifter? If that button currently just drops the CVT to low range I can do that by pulling the stick back. It would be safer to have Sport Mode accessed here, I think.
Any input would be welcome guys. Thanks!
