PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Tue Aug 26, 2003 8:00 am
they are located at the front of the motor, just open your hood and look at them, and yeah, they are pretty easy to tighten. all you have to do is first, loosen the pivot bolt or whatever its called (this is the bolt on the alternator that connectes it to the block for the alternator belt, or the bolt that connects the power steering pump to the block for the power steering pump/water pump belt), then tighten up the tension adjuster bolt. it should be pretty much the only other bolt connected to the system.
