I wonder about that too. Which bolt pattern & offset would be for our coupe?mikegtr06 wrote:do you think that the nissan center caps will fit ?
The same as every other Altima.5x114.3 high positive offsetrazah9 wrote:Which bolt pattern & offset would be for our coupe?
If you get the 18x8, I would recommend a 245/40-18.theanswer wrote:anyone order these yet? i'm interested. not sure what tires i would get with these...
I just got off the phone with tirerack. Website wouldn't list it as fittingour car so I call & the guy just kept saying it's not going to fit. That theygot the bolt patten info & a technical dept. that wouldn't guarantee theyfit or something so he didn't budge. This sucks...digitalbow wrote:^ no one mentioned a +40mm offset... and I dunno why you would need that specific offset.I think a +35 or +45mm offset would be fine. +35 is going to be a bit more aggressive, but on an 8" rim I don't think you will have big issues with rubbing unless your tires are wider/taller than a mid-low profile 245mm or if you are on a significant drop or have a heavy system.
Google is your friend...TireRack has them for $142 in 18x8 +45mm.They're 25lbs each, cast (Al).
Peoples have been running crazier setups arround so yours should be fine.razah9 wrote:
EDIT: Also 1010tires.com said they're backordered in my fitment &"225/45R18 is the correct tire size."
But didnt someone recommend 245/40/R18?
Modified by razah9 at 6:44 PM 1/21/2009
Thanks. Wish I could get OEM 18 Replicas! All day I wasdebating tire sizes in my head & I was leaning toward thatexact setup cause I'd prefer a 45 over a 40 for comfort reasons.I know bigger wheels are harsher but want to minimize it.marlin29311 wrote:
I'm not positive, but earlier I was researching about the center caps from Z wheels, and I'm pretty sure they are the same as on our stockers. These are G wheels though and they are replicas but they are likely still the same, I'd definitely try them before I bought new ones!razah9 wrote:Can anyone point me in the right direction to find Nissan center caps for them?
Here they are mounted on an Audi TT:theanswer wrote:did anyone end up getting these? i know its stupid but i want to see pictures..
how can you compare the hotness of the g37 replica to that rim? lolRmuth25 wrote:I like those replica g37s, but what I like even more is the Sport Edition F10s with black accents. From the picture I think they would look incredible on a black coupe.
http://www.tirerack.com/wheels...Brand
$141 a piece ain't too shabby either.
On a black a/c they are only better, also, I like the real ones a bit more then the replicas anyway, the real ones seem to be a bit more curvy and have that gunmetal color to it. Either way they are both nice wheels.mcheddadi wrote:how can you compare the hotness of the g37 replica to that rim? lol
the replica's or those terribad black machine cut tirerack link rims?08altima35 wrote:those are butt fugly!
and a sedan please? thanksCoupeguy23 wrote:could somebody photo shop these rims on a coupe for me
