replcing n70 stock airflow meter to a n60,larger than stock
blackhole1
Car: 95 s14 sr20
has anyone made this up grade.I have three wires on old air meter,five on new please help
180fan
Car: 89 fastback
there was a thread like this earlier. search for "300zx mafs" btw you got something to change that air flow signal to something your ecu can use like a reflashed ecu or an afc?
l80_240
Car: 07 Versa SL Hb, 99 Xsara VTS, 95 240SX SE, 94 Sentra XE, 84 Firebird 406ci
you cant just swap them in, same as 180fan said youll need a remap, piggyback, stand alone or else youll run bad cause the sensors are differnt, the n60 is from a maxima but i think the kits for the n62 300z's will work if you want to spend money for a connector, but if i recall something about not useing the other 2 wires...not 100% sure on that, someone else will let us know or you could search.....
