ReplacingWorn&TornParts
Type X(J)
Car: '98 240SX SE
Wassup guys...i'm lookin on parts/things i should replace/look into.i read that the more mileage the car has, the more problems it'll have.I'm putting together a list of parts that I'm replacing in my proj. '89fastback. i bought the car with more than200k's on it. white smoke has appeared from muffler and grinding can be heard when the cars in neutral. carpeting under clutch and gas pedal look very worn. springs were compressed and it had a big fugly muffler. Body's straight. some water leaks in trunk area and in drivers seat, prolly from sunroof. its basically a shell, jus' wanted to know what things i should be lookin for in the body and in other critical places in a car with high mileage.MyLists: replace engine transmission (syncro, flywheel) brakes (master cylinder, rotors, pads, steel lines) dampers&springs and bushings drivers side door hinge thnx much
