Replacing weatherstripping
Destructo1
Car: 2001 Pathfinder LE
is it difficult to do? Weatherstripping, meaning the rubber on the inside of the door when you close it. I got my doors realigned and that did nothing so I'm thinking it's time for fresh rubber. (hissing from wind on highway) Is it hard to replace? Where is the best place to get it? Price range? Appreciate the help guys!
Pwnin O'Brien
It's an extremely simple process, try pulling some up and you'll see it's not on there that tight. Some of the weatherstripping may be tucked under some of the interior trim but you can just carefully pull it away and it will come off. It might take you two minutes to remove the trim for one door and five minutes to put new trim on. Maybe some of the weatherstripping just needs to be re-adjusted to get rid of the whistling.
Destructo1
thanks man.. Ill try moving it around a couple more times.. theres definitely some miniscule cracks which is why i think it needs to be replaced... but ill definitely try to save the money haha
