Replacing water pump help
flyhighusa
Car: G35
Long story short i'm trying to replace the water pump. and made a BIG mistake.
While trying to loosen the tension on the timing chain the little plastic piece broke off and fell into the timing chain case.is there an easier way to find it besides taking all the pulleys off and the timing chain casing?
thanks guys!!!
its the plastic thingy that goes in the opening of the middle pocket on the tensioner as pictured below. Not even sure if I can buy this.
Modified by flyhighusa at 3:54 PM 9/21/2009
Modified by flyhighusa at 3:56 PM 9/21/2009
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
I doubt it. I think you have to take off the entire timing chain cover. If it was metal you might be able to use a magnetic thing...but that would be hard. Either way, good luck.
Maybe the Techs will have some insight on this??
flyhighusa
Car: G35
I'm going to try to remove the pan on the bottom and hope it fel in there :-) if there are any other suggestions I welcome them.
thanks for the never ending help I receive from you TBWilly
tollboothwilley
Removing the belts is very straight forward and easy. Removing the front timing cover shouldn't be much of a problem.
ByThaBay
Car: 2005 G35 Sport Sedan 6MT
I just finished editing a video that demonstrates replacement of the timing chain tensioner and water pump:
http://x.infinitihelp.com/forum/showthr ... 11851.html
