SD95infiniti »
https://forums.nicoclub.com/sd95infiniti-u45527.html
Fri Aug 18, 2006 12:45 pm
I have a coolant leaking and it is coming from the water pump on my 95 J, I am thinking of replacing the pump myself. Some of the mechanics that I talked to suggested that I replace my timing belt, Cam Seals, T-Belt Tensioner, Spring - tensioner, Coolant hoses, Thermostat, and all the belts, reason being, I am already inside. I bought my J30t in 2000, used, and do not know if the belt were replaced. The car has now 123K on it. The only thing I would like to do right now is to fix the leak, for I have no $$$ for the rest to the parts. What do you guys think? and how hard is the actual job. I am a DIY mechanic but not really in this kind of repair.
