miata007 »
https://forums.nicoclub.com/miata007-u31566.html
Mon Jan 16, 2006 12:01 pm
Status update:I finally decided to work on the valve cover yesterday afternoon. (Half way there). I removed the plastic cover/harness/tubes...atleast disconnect them. While removing the bolts of the valve covers, I was surprise to find out how loose the lower ones are. I put my ratchet + socket to a bolt and turn counter-clockwise. It felt like I didn't not put the socket in right because felt no resistance. Turned out the bolts were so loose that I can remove them with my fingers. The bolts removed on the lower end were wet with engine oil. No wonder my car is leaking badly. I could have just tighten them to see if the leak goes away but since I already bought the gasket and silicon I might as well do it now while it is easier.
At the same time, I am replacing two knock sensors and it's harness (chewed off by mice). I am going to take some pics this week when I get a chance.
To be continue next weekend... (Thanks for all the helps so far!!!)
007
