vancouverbc wrote:
turn your ignition to on and listen for fuel pump. it will come on for 5 seconds. the pump is in the hatch. if you have a powered antenna that complicates it a bit.
I do have a power antenna...which makes a wonderful "click click click" even though the head unit is off and the antenna has been stuck in the up position for the last 4 years.
Earlier you said to put a screwdriver against the injector and listen for clicking to see if it works but I could not figure this out. None of my injectors sound like they are clicking.
I know the fuel pump works because the car is running, just cyl 2 is not firing.
Eric
