alexf20c »
https://forums.nicoclub.com/alexf20c-u34818.html
Thu Jan 21, 2010 4:01 am
you got under the truck yourself and put your hands on the driveshaft and saw the play in the u-joint? you would also get a horrible vibration while driving.
a clunk could be worn upper control arm bushings, or a motor/trans mount. there will always be some "play" in the drive shaft if you try to spin it by hand.
the u-joints don't go out often if at all on R50s, so be double sure before you spend money and start taking things apart.
