Replacing TPS
alex61089
Car: 1993 Infiniti J30t (crashed)
2006 Nissan Altima SL Special Ed 31K.
Ok so i ordered my TPS from pepboys (24.99) and I'm curious.. when i take out the old one and put this one in is there anything in particular i have to do? Like reset or set the voltage? thanks.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Yea return it and get the OEM one new or used from a junk yard, Trust me.
Look in the service manual to install it: http://Nicoclub.com/FSM/J30
J30inthe sun
Car: 1997 J30
alex61089 wrote:Ok so i ordered my TPS from pepboys (24.99) and I'm curious.. when i take out the old one and put this one in is there anything in particular i have to do? Like reset or set the voltage? thanks.
The one I bought from Pep boys came in a different brand box than OEM, but when I took it out of the box it was the OEM brand Hitachi with the exact same part # on it as the factory part. It was @$56.00 for me at Pep Boys. Good luck!
alex61089
I just looked through the whole service manual and there is nothing in there about installing a TPS only information about the TPS or maybe im just blind.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
The TPS is attached to the side of the driver's side throttle body (soft aluminum) by two SMALL screws.
It, along with a number of other ECM inputs, determines idle speed and transmission shift points. Rotate it too far one way and the idle speed will be low, the transmission will shift too early, the OD lock-up may at hunt at freeway speeds, cruising rpms will be high and freeway gas mileage will suffer.
Go too far the other way and engine rpms at idle will be high and shifts will be very abrupt.
After installing it you'll need to adjust the output voltage with the engine fully warmed up and idling to between 0.40 and 0.45 VDC. I've posted a photo a couple of times of one connector leading to it with a strand of copper wire inserted into the backside of the connector for purposes of measuring the output voltage. Try using the search feature.
After setting the voltage using a digital multimeter and with the engine still running, you need to momentarily unplug the connector (the engine should stumble a bit) and then plug it back in so that the new output voltage is registered in the ECM.
yodawill2000
Car: 94 Infiniti J30
Off Topic:Get the Consult working GerryO ??
It shows TPS voltage on the gauge screen.
alex61089
ok i just got the part and its in a borg warner box but i can see it has nissan on the part but it looks like they tried to etch it off? hm. Well im pretty sure that i dont have the copper wire comming out for testing; so whats next?
yodawill2000
You supply the copper wire You insert it into the connector to test the voltage.
alex61089
lol i feel like a dee dee right now. haha. Well i was looking at the tps and the moron who owned the car before me didnt have a bolt in the bottom of the tps so i think i'll test this one and see if it works because my thoughts are one bolt= movement while driving causing my problem.
yodawill2000
Bet that's all it is ..Just a slight rotation will make a big difference.Replace the bolt and then check the voltage and adjust accordingly.Mines dead on 0.45
GerryO
Car: 1993 J30t
Pearl White
Black Interior
yodawill2000 wrote:You supply the copper wire You insert it into the connector to test the voltage.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
yodawill2000 wrote:Off Topic:Get the Consult working GerryO ??
Haven't given it another try just yet and nothing definitive in terms of help from Jason. Maybe this weekend. Sure wish they hadn't coated the circuit board with so much black stuff and it's encouraging to hear that yours is working so well.
yodawill2000
betcha a donut a serial to usb cable and the proper driver will get ya going !!
alex61089
do i need to use alligator clips?
yodawill2000
Just place the wire like GerryO posted and measure between it and ground with a volt meter
alex61089
what size bolts go into the TPS?
Infinitiguy19
What I mean is Pepboys, Auto Zone.... rebuilt or new stuff are not as good as OEM nor are they made with the same care, knowledge and parts as OEM.
But the bolts are 7MM.
alex61089
Ok so i placed the new TPS in there and set the Voltage to .45 exactly and now my trans shifts fine and i have no draw back or sudden rise or decrease in RPM. I'm idling around 800 RPM when in Park. So new problem lol... When i hit 80MPH to test it out and then parked afterwords (around 3 min later) I put the car in park and it was idling at almost 2,000 RPM? but when i turned the car off and back on It started idling at 800 RPM. Weird? I have no idea whats up. Man One problem arises with fixing one
GerryO
Car: 1993 J30t
Pearl White
Black Interior
alex61089 wrote:Ok so i placed the new TPS in there and set the Voltage to .45 exactly and now my trans shifts fine and i have no draw back or sudden rise or decrease in RPM. I'm idling around 800 RPM when in Park. So new problem lol... When i hit 80MPH to test it out and then parked afterwords (around 3 min later) I put the car in park and it was idling at almost 2,000 RPM? but when i turned the car off and back on It started idling at 800 RPM. Weird? I have no idea whats up. Man One problem arises with fixing one
Dirty/sticky AAC or IAC valves, throttle bodies or tight/binding accelerator or Cruise Control cables?
Infinitiguy19
NOPE, you have to clear the ECU of the self learn parameters, You need a consult for that.
Clearing the codes MIGHT do the trick but I doubt it.
You need a Laptop consult by Blazt.biz or a real consult which the Infiniti dealer has, now would be the time to buy the Senior Infiniti tech some lunch.
alex61089
If it helps to narrow it down when i first replaced the TPS my HICAS light came on? then when i restarted the car it went off never to return again lol.
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
GerryO wrote:The TPS is attached to the side of the driver's side throttle body (soft aluminum) by two SMALL screws.
im confused about what your talking about to rotate...please explain or take a picture...im having shifting problems myself and recently replaced the tps....
alex61089
I'll take some pictures for you and show you it seems very complicated but easy enough once you figure it out
joetraynor
Car: 1994 Infinity J30 T
AWSOME.
