s13boost »
https://forums.nicoclub.com/s13boost-u122353.html
Thu Jul 02, 2009 7:25 pm
So it's a ka24e. Bought the car from a guy who couldn't get the car to start. I figured out the guy had the spark plug wires on a**-backwards, so i fixed that. So then it would only run if i was giving it throttle, no idle. The guy put a new head, new valvetrain components, new timing chaing etc.Reading the write-ups, it seems the car is at top dead center. Distributor rotor at 4 o clock, crank pulley timing marks at the 2nd from right, and with the valve cover off the dimple on the cam sprocket is at about 3 o clock.Looking at the timing chain, i see the link that is lighter in color like the write-ups say. But he also has a link with a sharpie mark on it, however neither one of these links is at tdc.My question is, being that everything is at tdc, does it matter if the marked links aren't where the write-ups say they should be? and if i decide to take everything off and replace the timing chain to where it SHOULD be, is it necessary to drain the oil? not a big deal, just wondering cuz some write-ups don't say anything about it. any help would be appreciated.
