Poyzinous »
https://forums.nicoclub.com/poyzinous-u125838.html
Sun Jun 28, 2009 5:57 am
Fairly simple really.Car must be off. Key out of ignition. Remove the two Hex bolts on the sides of the steering wheel cover. You may need to buy the Tamper-resistant type bit if its available. The Air bag module slips off easily. CAREFULLY remove the connectors, slide a thin 1/4 inch screwdriver tip to lift the connector clip off, and disconnect. Set it aside, and then you'll need a 19mm deep socket to loosed the steering wheel nut. Just break it loose, then shake the wheel a little to break the metal to metal clasp and remove the nut and the wheel slips off. Be careful with the spiral cable and dont move anything around. Look at the alignment groove on the wheel and make sure it slides back on at the exact same spot as the old wheel. Reverse procedure from there and you're done.
