Replacing the climate control
Nissan5
Car: Nissan Pathfinder's and Frontier's
I have a 2001 LE Pathfinder with Navigation (GPS) installed. The buttons for the climat control are falling off, so I purchased a used climate control module for it but the wiring harness did not come with it.
Has anyone else encountered this problem? I live in York Pa and I can not find any Pathies in any salvage yard, yet alone an LE with this module.
Any shortcuts and or easy solustions?
Bob
atraudes
Car: 2001.5 Infiniti QX4 4WD
Are you talking about converting the climate control system from that which is built into the navigation unit to a non-navigation setup?
It sounds like the OP on this thread had the same question as you:
update-removed-navigation-and-rewired-a ... 01-30.html
I did the same with my 2001 QX4, and have a writeup of what I did here:
update-removed-navigation-and-rewired-a ... n#p6532852
The full thread will give you an idea of what's involved and some background (you're not the only one with buttons falling off). A full control swap isn't for the faint of heart, but it's totally doable.
If you're looking to just replace the buttons, apparently Shizelkadizal has cooked something up:
post6561910.html
If I'm totally missing the mark on what you're looking for, can you elaborate?
