monkey228 »
https://forums.nicoclub.com/monkey228-u141539.html
Mon Aug 24, 2009 4:34 am
I just did mine this weekend, so would like to share my experience. (1) pop out two little square shape plastic covers near the back end of the trunk (near the light assembly;(2) after removing the plastic covers, you would see a securing nut (one behind each plastic cover) to the light assembly, removing the nut;(3) now is the tough part, most forum messages talked about pulling the light assembly straight out (do not pull sideway as it will break the assembly) but it didn't work no matter how hard I try. So I refined my method and it worked pretty good. Stand on the side of car facing backward, put both hands on the light assembly plastic body and give it a burst of push toward the rear end of the car. you should hear something has "un-clipped" then gently pull the assembly out. Once the assembly is out, then it is very easy to replace the light bulb.You should also see the clip at the sharp end of the light assembly and make sure to align it first when you put the light assembly back.
Goo luck!
, the clip at the tail end (the sharp end)
