.::SHIFT_Z32::. »
https://forums.nicoclub.com/shift-z32-u96508.html
Wed Jun 09, 2010 3:36 pm
So, the other day I decided to clean my battery terminals and battery cable connectors. After cleaning them I went to put them back on and tighten them up but my negative battery cable connector was still sloppy and loose even though I had completely tightened the nut. After closer inspection of the negative connector it seems that the lower portion of the connector that fits around the lower portion of the negative battery post has a crack through it. How that happened.... I don't know.
I priced a new set for both the negative and positive battery cables from Nissan and it looks like it will be about $80.
Here are my questions: How difficult is it to replace these cables? I know the top half would be simple but what about the other end of the cables. I can't see where the cables go by looking from the top of the engine. I know the positive cable connects to the starter..... is that easy to get to? And does the negative just connect somewhere on the body? Thanks for any help!
