replacing the alternator
Nagalf
Car: 90 Nissan 300zx n/a to tt, 87 mustang 5.0 cobra, 97 gst
does anyone have a write up on removing and replacing the alternator? I could usea bit of help
NolimitZ32
pull out the radiator, pull of tensioner bracket, remove big alternator bolt, pull forward, remove all connections, REMEBER which wires go where!
Villain3g
Car: 1992 Nissan 300zx N/A
I didn't have to pull the radiator to replace my alternator. It wasn't fun tho. Here is the write-up I used
http://www.twinturbo.net/net/viewmsg.as ... _id=929376
REDWINTERZ
Car: 1994 Nissan 300ZX (Aztec Red with Black Leather)
@Nagalf:
I had to do my alternator within weeks of buying my car (my Z is my first car). I've had no previous automotive experience either. If you are good with your hands, it isn't very hard. Just take it one step at a time, and you will have no problem. If you have any issues, let me know!
And IMO, pulling the radiator and fan make things a lot easier...
Here's my favorite pic from the replacement:
bentandbuzzin
Car: 1992 300zx n/a manual 2+0
REDWINTERZ wrote:@Nagalf:
I don't mean to jump on this post but i see no sense in starting another of the same topic. Anyways did you use a aftermarket or oem belt for replacement? I have a aftermarket belt and it seems about an inch too long. When i adjust the belt i run out of adjustment and the belt is almost tight but not enough. So i'm guessing that the aftermarkets are longer than the oem belts.
