3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Mon May 28, 2007 7:34 pm
yup.
nissans like to be taken apart. they don't giveup the cherry without some foreplay, ya know.
my preffered nico tutorial is by greenq45a (active model).
even if you are std, drop the tension rod bracket, drop the a/c--upper rear bolt on a/c is a pain, but do it as a straight thin 3/8 drive ratchet on 14mm.
take out the outboard (12mm) bolt on alt first, then crack the 14, rotate alt CW until it stops. this will give you an 1/8 inch that makes a big diff to get the a/c out. then after the a/c is out it's straight forward.OEM reman only---you don;t want to do this again soon. check your pulleys. oh, and what about your chain guides---you've already done those, right?
