Replacing stock radiator fan!
bearsfan00
Car: 1991 240sx
I took off the stock radiator fan and wired the A/C fan to the fuel pump fuse To cool the RAD. The radiator cools the motor fine no problems. But It stays on all the time when i turn the ignition switch on and it gets on my nerves. I turn off the switch and it seems to be staying on like 2 seconds after the switch is off. Any way to wire the fan to a different source so it would turn on wen it needs to?OR IS THIS JUS FREAKING CRAZY WHAT I DID?ANY ADVICE?
91 KA24DE
Chris28
Car: 92 s13 KA-T
The A/C fan is not sufficient to cool the radiator. If you want to tun electric fans then I suggest either Altima fans or something like Flex-A-Lite. Find a relay in your engine bay that has a switched power source and tap into that for power.
Are you sure that it's not just the fan slowing down from momentum after you turn your car off?
bearsfan00
Car: 1991 240sx
Yeah,I think that's what it is. What relay that's the question. I haven't had any problems with the fan or overheating but at the same t ime I know it's not safe at all.
rudy543us
Car: 89 240 SX
You can go with the Altima fans or just find a good 14" or larger electric that will fit. Buy the Hayden thermal switch $25.00 from a parts store. This switch allows you to dial the exact temperature the fan will come on.
The A/C fan barely keeps the A/C system from over heating I would think you are playing with fire.
Good luck.Rudy
