centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Apr 05, 2016 12:26 pm
Only two bolts hold on the starter. I think if you got two off of one side, you pulled a transmission bell-housing bolt. No big deal, just put it back when you're done. The way I get to the top one is from under the car, from the rear (transmission side, not engine side). You can feel the bolt, it is exactly across the center of the starter bulge from the other bolt you've removed (see your new starter and know where the two holes are). You can barely see it, but don't need to. Put your socket on there and you can do it, but not with much leverage or room for cranking. If you have a nice long extension or two, then you can get your room for leverage and cranking. I used my extensions to make it like 2 feet long. That puts your hand and wrench out of the transmission tunnel and more under your car. PS you should be able to see this bolt by looking down on the starter from very close to your firewall.
