Replacing seats
Nissan 350z / Nissan 370z general community discussion forum
Ish
Car: Daytona Blue 350z Track
Does anyone know what to do about the seat belt warning light when you replace the seats in the Z and use a harness setup?
I'm trying to do some research as to what I need to look at before moving to a set of racing seats and 4 point harness restraint setup
Ish
'nother q,
Does anyone know the dimensions of the stock (cloth if it matters) seats?
NISTECH
The seat belt buckle switch plays a part in airbag detination. If they are buckled in a light impact the airbags will not detinate. In a moderate to hard impact they will go off no matter what. But the reason for this is to reduce the cost of a repair during an accedent as the G force in a light impact with the seat belt on does not require the need for airbag deployment. Now if you were to jumper the switch so the light stays off all the time then in a light impact the bags wont deploy, meaning if you dont have your seat belt on you will likely be injured. If you wereing your seat belt religously then I just told you how to get the light to go off.
Now if you swap out the seats all together remember you may have airbags in the seat back. So then you would be back to squre one and have the airbag light flashing. In that case you cant simply jump 2 wires to turn it off.
Ish
thx
I have the cloth seats, so no airbas there...
Im beginning to think that with after market seats I should still be able to just keep the buckle. That is what I would rather do anyway, so that I could use the seats without harnesses, then when I upgrade to harnesses just bolt them in as well as the seat belt buckle
paemt6220
Car: 1997 Maxima SE 5MT - MODDED
Remember, If you install harnesses, you should also install a harness bar. Harnesses that are bolted directly to the floor and not routed over a harness bar can cause serious sholder, neck and spinal cord injuries if you are involved in a serious accident. I can explain further if needed!
Chad
Ish
Found an awsome harness bar setup... also been talking to Sparco... they will have a 350z harness bar available in the q4 05
paemt6220
Great, many people make that mistake and don't use the harness bar.
Chad
Return to “350z / 370z Discussion”
