I have an S13 with an SR20, and a ton of other work done to it. There's a lot of money in this car, since I've had it for nearly 10 years. I haven't had the opportunity to drive it more than once over the past two years. I wanted to put it to good use again and went to install some R34 seats that I've had for a while. When I went to remove the drivers seat, I realized the rear, outside bolt was bolted into pretty much a rusty mess. I removed the seat, but there's too much rust to put it back in safely.
So my question is, can/will a body shop replace the rear floor pan? I'd like to make it drivable again. Just being that it's a unibody, I'm not sure if they would cut out a big chunk of the floor and replace it...
Thanks for your help!
