spreader? i have always used a C clamp to compress the piston....Promise Land wrote:You don't need to remove any fluid from the system to change the rotor. If you are putting in fresh pads, you will want a spreader for the piston in the caliper so that it will allow a thicker pad to fit over the rotor.
